The truck can sit for a week or two and you go to start it and it starts with no delays. Then you can be running the truck, stop it at the store and then it will just crank with no fire, not even a slight fire. One time long time ago, the truck stopped will moving over some ruff terrain. The ignition switch is wore out and you have to mess with it to line the key up. Also, you have to move it slightly to stop the chime even after the key is removed. Could this be my problem? If so I would like to over ride the key and go Nascar style. Have a on switch, start switch, and run switch. Just don't know with wires do what. Which wire to the IP is the fuel shut off? Maybe if it happens again, I can remove that wire, or supply 12 volts to it depending on how it works to troubleshoot.
