beretzs
Alright guys, I have a mystery for you. I went and got my haircut tonight and drove the truck, finally getting to drive the old girl a little more since diesel has came down to the same price as regular unleaded. Well, the truck has been running and starting fine, but tonight when I came back out to get into the truck, it started then stalled, well, I figured maybe it was out of fuel for that tank. I switched and then figured it may have air in the system, so I pulled one of the rubber caps off of the injector return line cap. it ran fine with the cap off, it was squirting fuel everywhere, but it was running fine, as soon as I put the cap back on (figuring all the air was out of it) and the truck quit immediately, I mean flat out quit, didn't hesitate or studder, just flat out quit, if I took the cap off it would start back up and run fine. But with that return line off, it squirts out a pretty solid stream of fuel. So, whadda you guys think, blocked return line (it has been parked for about 6 months). It has been running fine for the last two days. Any ideas, I am lost on this one, it is getting fuel, air, there are no leaks (well when the plug is in place).. What would make the truck flat out quit like that? It is just like I put a rag over the intake and there is no air.. I am stumped.. Scotty
