The FSV is a really simple device. It's a motor with a screw on the end of it, and a plastic valve that moves. The top can even be removed from the bottom. I've never tried to take one apart, but I wouldn't be surprised if you would be able to fix it. The top two pins run the motor. Just put 12 volts to them, and reverse the polarity to switch the other way. Their is a set of contacts with some diodes inside that turn the motor off when it reaches the end of it's travel. If it is blowing fuses, it might be that the motor is stuck, or the diodes are blown, but it would be real easy to bench test it.
