sound deadening the ip ?
mcbg
az
would it be safe to use something to keep the noise from the ip down?
maybe like a syrofoam box or a spray foam?
HammerDown
Glenolden Pa
Also could be the injectors clacking like a bad valve tape in a wore out gasser. With a looooong screw driver carefuly press the handle to your ear and the other end on each injector then different areas of the IP.
Vincent
