Single / rear tank only conversion?
Clayton
Ky
I just installed a 33 gallon bronco tank on mine, Removed the mid tank as well. I like the single tank better myself, Everyone has there preference though. For me it's plenty of range.
dunk
Dunce
NJ
Advantage is not capacity, but the possibility of two independent fuel supplies.
57 gal capacity was an advantage for me this past week. Had to travel up into Canada passing through NY. Filled with cheap fuel in NJ, topped off in PA, did not fill until my return 750 miles later and still had over 5 gallons left. If I had a ZF5 I could have avoided paying high PA prices too.
If you even occasionally do some miles through high fuel price areas having 800+ miles between fuel stops is nice. Can also make better time without so many stops if you have a strong bladder.
fx4wannabe
Chattanooga, TN
I have a 110 gallon tank I can put in the bed. My limiting factor is my wallet. I can get places on that setup.
ntjapkes
