LCAM-01XA
Behind driver side kick panel. IIRC on an OBS it comes out thru the engine bay. Look on firewall directly below driver-side hood hinge, you'll see a huge rectangular connector, this is the bulkhead connector for your dash and cab wiring. Now outboard of this, between it an the fender, is another rectangular connector, it's about inch wide by 4-5 inches tall, with maybe 15 wires coming out of it on the fender side - this is the TCM connector, it plugs directly into the TCM. Bolt sticking out the middle, 10mm socket to remove that, and as you unscrew it it will unplug the connector for you. It appears the ground is up high on the fender's inner lip, in the top driver-side rear corner of the engine bay, about an inch or so below one of the two big bolts that secure top of driver side fender to cab. It is the only ground there. There is a 2-wire test connector attached to the same fender lip but closer to cowl, locate the connector and ground is a few inches forward of it.
Giving the TCM a better ground is highly unlikely to fry it. Your truck = your call tho.
