i was contemplating an aftermarket controller for mine,now that iv got a hd reman,but then i stopped and thought about it,and the only issues i have is keeping the plugs clean in the winter.so i cleaned the solenoid pack plug real nice this last time and then smothered that ***** with black rtv.id like to see an issue with it now lol.
it's nothing an aftermarket controller would have fixed for me.same plug.the '93's n/a controller (yes the '93/'94's optional turbo controllers are apparently different,but im not sure with what) operates the e40d exactly how i would program the controller myself,so im skipping the idea of going aftermarket.
true the oem setup was wired messy,but i know just about all the quirks and symptoms to help pinpoint any issue anyway.
Eric,
you still haven't addressed your issue.lockup should happen only in 3rd gear.approx 5 mph after 3rd gear shift.downshifting should be easy with goosing the throttle about 3/4 she should open the converter,downshift back into 3rd,then lock the converter back up.
try cleaning the main harness at the ecm again and run a devoted ground to your tps.
don't settle.keep at it regularly until it's operating perfectly.it's worth the effort.
