i was contemplating an aftermarket controller for mine,now that iv got a hd reman,but then i stopped and thought about it,and the only issues i have is keeping the plugs clean in the winter.so i cleaned the solenoid pack plug real nice this last time and then smothered that ***** with black rtv.id like to see an issue with it now lol.
And I'd like to see you go for removing that plug if the need for it ever comes... lol RTV on a connector is a permanent solution to a temporary problem, I prefer packing the thing w/ Permatex dielectric grease as it's non-conductive yet thick and sticky and don't wash away easy at all.
it's nothing an aftermarket controller would have fixed for me.same plug.the '93's n/a controller (yes the '93/'94's optional turbo controllers are apparently different,but im not sure with what) operates the e40d exactly how i would program the controller myself,so im skipping the idea of going aftermarket.
My edumacated guess would be it has to do w/ altitude and different behavior of the two diesel engines up high - the n/a loses power and so the TCM will IIRC pull the upshifts earlier as you climb up Mount Everest, while a turbo engine doesn't care as much (at least my Fummins don't seem to) for high elevations and lower air density there so there is little loss of power and thus no need to alter the shift schedule. The TCM determines altitude based on the BARO sensor, which will read the same for both n/a and turbo trucks, so the different shift schedules for the two are done in the TCM programming, hence separate controllers available. And actually there are 3 controllers: low elevation n/a, high elevation n/a, and turbo. To make things even more interesting, the Superduty trucks got their own controllers, again different between n/a and turbo. I'd really like to know what is difference between a F-Superduty TCM and a normal 250/350 F-Series and E-series (vans and trucks use the same) controller...
lockup should happen only in 3rd gear.approx 5 mph after 3rd gear shift.
try cleaning the main harness at the ecm again and run a devoted ground to your tps.
Aye, that lockup in 3rd is what ****** me off exactly - she goes into 3rd at like 25 (which is a good upshift point and I like it), but almost immediately locks, and truck goes "bleh" and falls on her face. I don't need 1200 rpms while trying to accelerate, but I don't wanna have to give her more throttle to keep her from locking up so early either - I like accelerating like a freight train, nice and easy, and that just don't happen when she locks at 30 mph. I've read rumors that the F4 controllers should have that lockup point bumped up to 35 mph on the upshift side (and 30 on the lockup release) which would work much much better, but this is not what Eric is experiencing... So till I get my hands on an F4 and try it for myself, I'm sticking w/ no auto lockup in 3rd at all (manual lockup only), it's so much nicer and more pleasant to drive.
Good idea on the ground tho, actually I'll take that and add to it that the TCM ground that normally connects to the firewall by the hood hinge should be taken off there and extended all the way to the driver-side batetry - this ensure the controller has the best possible ground, and thus rules out a bunch of funky behaviors.
