stealth13777
My bearings looked worse than that, and the cam bearings were the worst (6.9 unbalanced cam). Ring and bearing kit from Napa was very reasonable, especially when you consider all the other money you've put into parts for these motors. If it specs out like mine did, hone it, replace those wear items, do whatever head work is needed, then run it like you stole it!
Well, and balancing it isn't a bad idea.
