Popeye2347
It is about time to address the ride qualities of my 1994 F250 4x4 diesel. I knew it would not have a 'Cadillac' ride as it is a 3/4 ton truck, but after one short drive in my friends 1995 4x4 F250, it is a night and day difference. So, the question is how do I achieve a better ride?
It has right at 130k miles and most everything except filters, tires, etc are factory. I am riding on mild off road tread 10 ply @40 psi. Before you jump on tires and 10 ply, let me say that my friend's truck has almost the same tires @ 50 psi. [The "chalk test" shows 40 psi is what my tires should be inflated to for proper tread wear.]
My thoughts are two-fold. first are shocks, the rear I can easily move so they are worn out, the front ones are still strong, but still have 130k miles from factory new. [FWIW the truck has never hauled/towed any load heavier than a golf cart!] So what shocks would you recommend?
There is only about 2" clearance from the spring on the front axle to the rebound rubber.
I'm thinking of weak springs.....solution?
Quick 'n dirty thoughts are to cut the rebound rubber [snubber?], but the sane side of me says that will only cause a worse ride and break parts.....so...what if I were to remove all but the main leaf and install an air bag from the spring to the chassis? I personally have no qualms about a lift kit, but the wife goes with me quite often and she needs a small ladder to get into it now [knee problems] so a lift kit is out. My thought on air bags is not only a smoother ride but the ability to 'kneel' to make it easier for her entry and exit.
Any thoughts ideas are welcome, especially from those who have travelled this road before me.
