As for the gasket or LACK of one and RTV,
I'd encourage what was said here!
Just normal black rtv gasket maker. May be called "ultra black."
You tighten it down some, let it cure for a bit, tighten some more, let it cure for 12-24, then do final torque. IIRC.
Same stuff I used on my diff covers also.
I think someone mentioned the "right stuff" gasket maker.
But I also thought we had a few threads talking about it.
Yes, yes we have talked rtv to death and we will continue to do so.
Pan and pan rail must, Must, MUST, be better than surgically clean. Remember that a body has antibodies to fight infection and when you get cut and leak fluid you heal!
An engine does not have self healing capabilities to stop a leak. Thus pan and rail must be clean. USE Brake clean, followed by a wipe with a LINT FREE clotch with Acetone, doing this ensures absolute clean. DON"T touch it to test if it's clean either!
3/16" bead all the way around just inside bolt holes, then you can go back and close up bolt holes with a semi circle if you like.
place pan on
install a few corner bolts and gently tighten then install rest till it's just oozing out a bit, let it cure as mentioned an hour or so, tighten down a bit more making it squeeze out a tad more, wait 24 hours do final torque!
That's my method when I can and am not rushing! I've never had a leak due to failure of RTV.
If there is even a smidgen of oil on pan or rail, that prevents RTV from making good contact with that spot and though it appears good, that spot will leak as it already has a broken seal oil will find that spot and continue to seep out forever!
Now lets talk break in,
First you have not provided any info on the situation.
NEW cam?
Bored and honed and new pistons?
ETC,
My take and it's expensive...but worth it! this is with fresh pistons in bored cyl and so forth essentially a reman engine!
20 minutes initial run time from first fire, drain oil and change filter.
500 miles, drain oil change filter
1500 miles drain n filter change
3000 miles drain n filter change, commence normal oil change intervals at this point!
This is just me, OCD and experience past.
Except for that first oil change all that old you use is perfect for tractors, and cars and other well run vehicles, that you may not worry about.
That first change is critical as its the initial flush of the engine post reman. Cut open filter if you can and look carefully at it before proceeding any further too. You may see something you don't like
As for how you break in,
light travel first 500 miles no extensive idling, no really hi rpm and little to no load
second phase 1500 miles light load and medium hiway speeds for short durations,
third phase 3000 miles medium - light heavy loads varying speeds some hiway some back roads always keep in mind to not run one RPM for long durations if possible
Engine is good to go and you can load ***** out of it and work like MO FO now!
JM2CW others experiences will dictate their responses,
Al
