rpm questions
res0wc18
Everett,Wa
hey guys what kind of rpms will a stock first gen turn?
Where is it sweet spot?
Max cruising rpm?
rebel_horseman
Rt. Wing Extremist
West Florida Republic
The 6BT from the factory will turn a max of 2800 RPM. There are kits out there that i know of that will let you run up to 3200 with teh VE pump. Your rev limiter is controlled by a governor spring in the VE pump.
My truck tended to like the 65-70mph range and it topped out at 85. Don't have a tach in my rig yet so I don't have a clue what I'm turning, but my Y2K wiht the NV4500 and 3.55 gears that I used to have would turn 2000 rpm at around 65 or maybe a little more. It's been a while so I don't recall exactly.
argve
Resident Fruitcake
Gwynneville, Indiana
Cummins says in some of their specs sheets that you can run the engine against the govenor all day long without a problem - I will use a little more fuel but it won't hurt the engine - remember they used these engines as stand alone stationary as well as transit engines.
res0wc18
Everett,Wa
so that wouldn't be an issue? Hmm
Anyone else have an opinion as i share the same one.
