The CDR is a VERY simple device. Even if the Diaphragm is damaged, it''ll still work as it's designed to. The ONLY thing the diaphragm is there for is in the REMOTE circumstance that You ever get enough VACUUM to pull the CDR closed.(which Our engines will more than likely NEVER do. Even less likely with a turbo) Then it's supposed to shut, and stop the engine from pulling a vacuum from the crankcase.
The theory is that IF the engine pulls vacuum from the crankcase, it could possibly pull oil out of the engine, and feed it into the combustion chamber. In theory there would be a run away engine, self feeding itself crankcase oil. IF that ever happened, the key would be useless. And the only way to stop the engine would be to stop the oil flow (fuel) or stop the air flow.
That is the very base function of the unit. The overall function is a bit more complicated. It is not a crankcase depression shutoff, it is a crankcase depression regulator, and aptly named, it regulates the pressure in the crankcase in a kind of push me-pull you type of balance designed to maintain specific presures pos\neg at different RPMS
