For those who have done it right, how does the truck ride? Empty and loaded. All the trucks I've played with had the shackle in tension so I'm not sure about the ride with it in compression.
On a side note with the shackle flip, i would suggest F-450 or custom shackles. Seems the stock ones can break/bend. Also the axle will move fordward slightly so ya either need to run a zero rate block or move the front spring hangers back about an inch.
Thanks guys.
On an unrelated note got a case of sticker shock when looking for parts they want 400 for a ******** starter for a quad ***?
If the truck is used for hauling, Dont do it. I reversed the reveral on my last truck becasue it was really squirrley under load. There are several threads on this very issue on other forums if you look for them.
Nice for a mall crawler or toy tho.
