yes all plugs still good, test around .1-.4ish ohms
yes all grounds are great twin 2/0 grounds, one battery to block, block to frame, other battery to frame. Relay is from a western plow dealer, 150a 100% duty cycle, 600 amps in rush. remember this is like the 4th relay i tried as well. I tried one of the plugs in "open air" with the others hooked up, it got red hot in 2 seconds.. this was the first plug in line of the harness (cyl 1)
im wondering if my huge compared to stock wiring is such low resistance, somehow only the first few plugs get juice and the rearward ones dont? My new harness is a long 8 gauge wire, with little drop harnesses for each plug, basically each bank has the plugs in parallel. Not having the Z strip affecting it that much? But it limits current as it heats up..so like we mentioned, seems the opposite of what I need..?
that controller should be in today. i took the car to work, truck is cold (shoudl be up to 70 today though!), I will take apart the battery terminals clean everythign up make sure it is all fine and dandy. I noticed some corrosion yesterday from under the terminal..perhaps laser you ar eon to something where the full current isnt getitng passed.
Will clean, reassemble, glow for 8 seconds and it should light off very quick. If not, ill put the controller/z strip in and try again, will keep you posted, thansk for the help so far.
