Soooo..... current update.... and what NOT to try
Attempt #1: Cheap nylon flex fan, bolted into 1/4" plate welded to a cut off fan clutch nut (balanced on the lathe), bolted into threaded holes with blue locktite.......... the bolts worked their way out....... minor damage, I got lucky on that one
Attempt #2: New nylon flex fan, same setup, bolts through the plate with lock washers and locknuts on the rear, fan disintegrated at the hub, hub still bolted to the plate, no damage but it only lasted 200 miles.......
Attempt #3: Stock fan, same setup, made a spacer to bring it out to proper spacing from a block of wood, ate a water pump in 1000 miles, might work, but I gave up on that because it went from no drips to spraying out the shaft seal hot and running.
Attempt #4: Stock fan, stock fan clutch, I drilled a hole on either side of center, tapped 1/4-28 and put in grease zerks, filled that thing with Mobil Mobilith SCH 1500 synthetic lithium grease (because I use it weekly on underground hoists and always have it), have been topping it up/checking it every 1000 miles,
currently on the truck at 8000 miles.
Truck runs up to temp, thermostat opens up, truck drops to 180, climbs back up to 210, back to 180, and repeat.
Not a full time lockup, but it seems to be (relatively) reliable so far, we'll see once it really warms up how she does.
