QUICK TIMING REMINDER PLEASE
Garbage_Mechan
Garbage Mechanic
Central Cal Foothills
Well, I'm flying home for 9 days and among the to do list while I'm home is to install the Baby Moose and matched BB's I ordered from Conestoga. The 91 is getting worse and worse mileage and power is dropping off. I've know for a while the pump was tired, but the wife's telling me it's wanting to stall pulling away from a stop and when feeding cows, and she's afraid to pull the gooseneck to haul calves to the sale here in a few weeks, so it got to the MUST level.
I have access to a Ferret and I've used it before but it has been a while. This is going to be a stressful situation so I don't want to be trying to remember anything. It looks like the agreed on setting is 9* for a turbo engine. Anyone care to give or point to a resfresher course?
FORDF250HDXLT
Maine & Oklahoma
agreed timing is 9? put me down for a disagree lol.remember the more fuel,the higher cylinder pressures.retarded slightly to reduce them as you add fuel.
i prefer 7 BTDC with intercooler and maxed ip.reduced engine noise pollution,same economy,she tows much easier,and turbo spool up is much quicker than 9 too.try it.you'll see.experiment since you've got the meter.iv run 9 and 10 before.not impressed.noisy and laggy.
refresher;
bring engine up to operating temp.
clean up # 1 fuel line and clamp on the piezo.
hook up timing light and set the advance to 8 BTDC (plus or minus two.)
set engine rpm to 2k.
line up o degree on balancer.
make ip adjustments only with engine off or risk ip shaft damage.
This ought to help you out!
Sounds like you may want to adjust some timing, so take a look here
http://www.oilburners.net/forums/sho...ight=IP+timing
Good luck if got questions maybe can assist further.
Al
Garbage_Mechan
Garbage Mechanic
Thanks Guys, I usually do a lot of reading and studying, but this time I have to get a lot done in a short time. Probably at least the the 10th pump and injector set I changed personally, just never had access to timing gear till lately!
This is the 91 in my sig, 7.3 5spd 4.10's. Never sees much highway, mostly secondary roads, hauling a few bales of hay and then hauling 15k or so pulling the gooseneck. It has a Banks sidewinder on it w wastegate. No IC. 150,000 on the engine.
