Waystro
No Class
Ok. So how would it be if I Did .020 with .10 reduced height like Soro71 did.
Are would I be better off to do 030 bore with 010 reduced height.
Do you have a machine shop you are going to deal with? Most of your questions will be answered when you take the parts in for evaluation. The oversize will be determined by the amount of material needed to clean up the bore. Earlier you were planning to use stock pistons. If your bores are still good you wont need oversize pistons. The same applies to your heads. They need to be checked for cracks before you decide on the next step. If the block needs to be decked to clean up the head gasket seal you may need to mill your pistons. What started out as a budget build can get pretty expensive. A late 6.9 block is a good base for a rebuild. I was expecting the expense but was surprised at how long it took to get everything back from the machine shop.
Not yet still trying to find a decent shop. That's what I'm planning to do have the shop look everything over and tell me what they think on the cylinder bores and heads. What is the benefits of going say .030?
Thanks for the shop recommendation I'll give him a call later.Try Ted's in Conroe, it's a reputible shop and they come highly recommended.
As far as cylinder boring and relieving the pistons for milling the heads or decking the block, you're going to have to see how much meat the cylinders are going to need cleared to become round & smooth again. In the gasser-world a +.030 bore will net you a few more horses, and still leave you with another .030 of meat to grind again later after another 100K miles. Now I'm no expert here (as I'm sure you've deduced already), but from what I gather, you'll only want to bore from the 6.9 block what is absolutely nessecary - ie: you don't want to go +.030 if +.010 is what gets everything back the way it's supposed to be, and I say this for two main reasons: 1) If a 6.9 is similar to the 7.3 IDI, then boring the cylinders could lead to the dreaded 7.3 cavitation problem, and 2) You'll want to keep as much meat on the block as possible for 20+ years from now when you want to rebuild that engine again.
In a perfect world, you'll only need to hone the cylinders, but when the machinist looks over the block, he'll tell you if the head mating surfaces are flat, and if not, then how much he's going to have to deck the block to get it right again. He'll also do the same thing with your heads, and check the mating surface to the block, and if they need to be milled flat again, he'll be able to tell you by how much.
Once you have all that information, I'm sure the more knowledgable folks here can chime in a little better with what is & isn't within tollerence, and whether or not you need shorter pistons, bigger piston valve reliefs, thicker head gaskets, recessed valves, fairy dust or a flux-capacitor. HTH, good luck & keep posting!
P.S. Sorry for the poor spelling, my spell checker is on strike
Now that's what was confusing me in the gasser world like you said going .030 or similar would net some extra HP
Like I said most of my engine tear down etc has been on a Dualport 1600cc VW so the idi is definitely a learning experience.
Oh by the way how is it coming on your end have you pulled it yet?
Well ford did bore the 6.9 120 thou. to get the 7.3..... right?
... Now can you sleeve a 7.3 down to 6.9.. Sure can and its going to end up a built proof engine for sure...
