Well, I I'm working on a plan to deal with the transmission. I wavered between slap it in there or make a mount or find a used unit. I think my strategy is going to be replace the tail housing. The only question is will I do it or let someone do it. It's only a question in my mind really because of what's actually involved in setting the bearing preloads. It's essentially a complete tear down because the preload shins are in the front case half. I've devised a plan to check preload with a new case half, but if the shims that are in there are wrong, it's nearly a complete tear down to change them. Then while-you-are -in -their-itis sets in. It's a nearly 30 year old unit, shouldn't it be freshened up? It's apart already. Why not put new parts in???
So anyway, I'm not sure where my line in the sand is but getting a complete core together, seems like a good idea. Weather I put it together or have it done will be a game time decision.
While that's on the back burner, couple things came in.
Got my banjo bolt adapters for the turbo water lines. They look good. I think they will work fine.
Hydroboost pressure hoses came in.
Electric vacuum pump came in along with the connector.
I can make up the harness now for it.
Also picked up this guy for the 3G alternator.
Plug and play. Makes the alternator basically 1 wire hookup. I had picked up a bare connector but I couldn't find the plug for the white wire. So for $15 this is a no brainer.
So I'm looking for some other connectors but I'm ready now to finish the engine plumbing and wire harnesses then I can go ahead and start painting and hanging panels and make the battery tray. Got to roll!
