I was away for the weekend but did a little shopping. I have raw materials for a intake hat on order. It will have 2.5" or 2.25" inlet depending on what I can fit. I also did a little checking and it turns out that you can get the hot side housing with the t3 undivided flange like I have in all three available ratios. I have the 0.89 which is the smaller one. Heath I think is running the 0.99. New housing is less than $400 so at the price I got the turbo, if I end up changing the hot side, I'll still come out ahead of full purchase price so I can live with that. It should spool quick with the smaller housing as long as it doesn't choke based on the little bit of data from Heath.
