Got it all taped off and wiped down. Then shot the acid etch primer (upol #8). That was what was recommended on the bare metal spots. There was bare spots all over it so I scuffed it all and shot 2 coats of primer on it as per the tech sheet.
I broke out the Raptor liner kit with the included texture gun. It went on real nice. Here's what one coat looks like.
Problem. I used 2.5 qts out of 4 in the kit. No way there's enough to do that again. Now what. Okay. New plan. Since this is to seal the metal up mainly, I went to the tech sheet whic says you can reduce 10% and shoot it HVLP. So I mixed the rest of it and put another complete coat on all of it and another good coat on just the floor. Here's the final product with the masking removed.
I stuck some cheap grade 2 bolts in the seat mount brackets to keep them clean. I dropped 5/16 carriage bolts in the seatbelt mount holes. Worked great.
