Alrighty, got the firewall plate fit and dry installed. After looking for the better part of 2 hrs for the screws, I found them... In the cab...with the rest of the steering column. [emoji35]
It fits perfect.
No adjustment needed.
By the way, you can drill the holes in the cowl from the outside pretty easy.
Need to do a little work to it. A couple washers will deal with the hack job for the clutch master.
I went and pulled the pedals off the shelf. Much to my irritation, the pedal box I was going to use that I got with the hydroboost is cracked.
If you look it's cracked around the hole in the upper right. Looks like it's trying on the lower right hole. The clutch rod is a little worn too.
So I went and pulled my pedal box off the shelf. It looks a lot better.
I'm guessing this is the vacuum dump for the cruise?
I don't remember anything being hooked to it when I tore it down but it had been molested so who knows.
I'll tear it down and paint it up. Maybe some fresh bushings.
Not setting the world on fire but it's progress.
It fits perfect.
