shawn deere
So many wrenches, so little time...
Did you keep the fan shroud intact?
Turbo waste gated? Up pipes sealed up good like?
Man, thats a real bummer!
I didn't get to pull it again. I did drive it to work this morning.
Called Redhead. Guy said it sounds like air and he has had boxes take weeks to bleed out completely. I believe he's trying to blow smoke up my ass but I guess I'll toss it back in and see. It was definitely tight so that will help that issue. Maybe I just didn't get it bled. I doubt it but I suppose anything is possible. It's just a real PITA to change the damn thing.
I guess that's tonight's adventure. I'm also going to check out the mirror head situation. I have 1 of the universal heads floating around. If it will bolt to my mount I may try it. I saw that on somebody's truck a while back.
Fan clutch shipped.
This is going to be to the wire. Hope I make it.
Can't floor it for mor than a few seconds before EGT's get out of hand. I just happen to have a couple Teflon washers in my pocket to try and see if the seal around the hat bolt is bad.Sounds like between towing and fan clutch we have a lot of the same issues! I'm hoping my new ford clutch is the solution as well.
When your turbo is only boosting 5 psi do you have it floored? Mine only seems to make higher like 9-10 if it's floored. Otherwise it's usually 6-7 range.
Wow I see. My egt will go up but nothing crazy even floored. I suppose if I kept in it on a hill they might get up there but I haven't had it creep much past 1100. And empty it doesn't even get closeCan't floor it for mor than a few seconds before EGT's get out of hand. I just happen to have a couple Teflon washers in my pocket to try and see if the seal around the hat bolt is bad.
