Nope it will be prefect
Since I deleted the vacuum pump, I'm not sure I could even use a standard serp system. I'll give this a go. It seems to be getting better. I MAY have had ATF on a belt after my issue the other night. It's possible. [emoji6]Oh Mike.You left this beautifully restored truck v-belt! 3 lashes with a wet noodle! Sometime down the road,look to see if someone has the serp pulleys so you can upgrade.That said,the gates belts are about as good as they get.
Good to see your fuel issue was just a bad ground to the pump relay.Troublesome and irritating but at least super simple to fix once you found the issue.
I have to disagree with this...... I've dealt with both systems, and on the IDI, I would rather have the V-Belts.....
