Problem with PM's
Russ
Idont do injectors
New Brighton PA
When I get the message that I have a new PM,(click OK) then a prompt to open in a new window,of cancel. If I click "OK" to open a new window. Nothing happens. Haven't tried to open in current window. Running Win XP if that matters. Russ
FaC
Central NC
Do you have pop-up blocking turned on? I am pretty sure that the PM is displayed in a pop-up window. Look right below the menu bars and see if there is a message that the browser has prevented a pop-up from opening.
FWIW - FaC
Russ
Idont do injectors
New Brighton PA
I 'm running a pop up blocker. That sounds right. Ok I'll have to disable the blocker on OB. Thanks for the tip.
Max Power
Or on the second window when it asks if you want to open it in a new window you can click cancel and it will open in your current window.
Ramprat
Inside your OODA
Not using mozilla, it does not open one at all & I've got to manually go to PM's & open it.
Swany
Consiglieri
California
Originally posted by Roland_Jenkins
Hold down the CTRL key and click on open in a new window. BTW I never get any pm's :cry:
there's probably a reason for that tooLOL
Mike
Stroker
Cora
RJ,
That might be due to the fact that you do not have "recieve PM's" enabled:kick:
Swany
Consiglieri
California
Originally posted by 95_stroker
RJ,
there's probably a reason for that too...
man, I crack myself up!
Cv axle
