Preperations for an Overland/Camp build
Kevo1288
Worcester MA
Over the last two three weeks I have been taking my pup off the beaten path in many areas covering a 100 mile radius. My truck is bone stock as far as suspension goes and tire size. I feel like my 94 f350 is pretty robust in stock form and am quite impressed with its manners to be honest. I do think a steering stabilizer is necessary to reduce some "bounce" in the steering as ive been getting a lot going over rocky areas. What would you guys recommend to "upgrade" if the truck was going to be a daily (20-25 miles a day) plus a weekend warrior.
I love the trucks power pretty much stock when it comes to idling up hills and over obstacles so don't really want to change much there mostly looking for chassis upgrades/preparation suggestions.
I don't plan on flexing like crazy either but if necessary, well you gotta. Id like to get up to a minimum of 33/34 inch tire size with room to articulate.
I think the idi 7.3 4x4 trucks would make some of the best overland adventure platforms out there due to the robust running gear and simplicity of the motor. Its a wonder they are so overlooked.
Thanks guys,
Kevin
Runningaford
Id/Az
There's a couple guys on here using their trucks as overland type trucks. Then again, there are a lot of us who live in areas where our trucks get a healthy amount of regular 4x4 use just from daily living lol.
Oledirtypearl86
Whitehall MT
I use my 86 F-350 all the time off road lately on a daily basis they are great rigs for it and my truck flexes pretty good nothing to brag about but with a crew cab long bed and a turning radius of a city block i am limited a little on some trails
Kevo1288
Worcester MA
Up here there’s not much 4x4 use until you hit the winter then it’s oretty common. I mean I just can’t believe how robust they built these trucks and why ppl up here rag on them. Once I do a zf5 swap I feel it’ll be pretty indestructible
Black dawg
sw mt
I really like a 255/85/16 on a stockish build. It is pretty amazing where mine has been with stock suspension, those tires, and one locker.
Kevo1288
Worcester MA
New bushings in the springs, slider material in between leaves, a winch, done.
Oh and PLEASE! stay off of chitt like expedition portal-Lame unless yer there to poke fun.
I love reading there but some of the people are such snobs! I had an 85 trooper ii camping rig and loved it. My idi has so much more potential though.
Kevo1288
Worcester MA
Me too! It’s that or I was thinking 255/100r16 military style which is a little under a 36
Oledirtypearl86
Whitehall MT
Hhahahahaha lame is an understatement iv delt with a few of these pud stains and all I can think is how have you not ran yourself over yet
MtnHaul
California
On a stock F350 front end I fit 255/85/16 no problem--they do come close to the bumper but no contact. For simplicity and reliable starts even with a few failed glow plugs I would install a manual glow plug switch.
A manual fuel shutoff mechanism instead of the 12v fuel shutoff solenoid in the IP would be a sweet upgrade IMHO. I'm sure it doesn't happen often but the thought of being stranded due to a failed FSS just don't sit well with me.
Thewespaul
Bulverde, Texas
If you put washers behind the bumper to get a bit more clearance, 285s go in without any running. If I was building an overlanding rig I would setup on board air and have a good inverter. As far as suspension, an rsk is gonna give you more clearance and ride much better off-road. Get a good winch bumper, replace any worn steering/suspension components and you are set pretty well.
Kevo1288
Worcester MA
I was thinking about using the space where the front tank is (once I do my big rear tank install) to build a pretty legit on board air setup and mount it in its place.
720Diesel
