PPump Timing Bump
snakebitegalvin
Duncan Arizona
I got my 94 runnin on wmo. Its got stock injection timing and I need a little longer for my fuel to burn. Is there a way to bump the timing without removing the cover like you can on the old VE pumps?
u2slow
bilge rat
Coastal BC
Can you rotate the pump a few degrees toward the head? (Loosen nuts and lines first). The next step is skipping a tooth.
That's about all I got for a p-pump; I only have VE's.
snakebitegalvin
Duncan Arizona
I'm gonna try rotating my ppump. I've only seen people do it on VEs so I wasnt sure but I guess we'll see!
Black dawg
sw mt
you dont have to remove the whole timing cover, but you do remove the filler, and have to have the puller and timing tools to complete the job. Pump does not rotate.
Mt_Man
Portland, Oregon
This guy has some interesting wmo vids too
radeon1314
