dyoung14
Is getting worn out
What would cost be with a used set of injectors
dude-
don't let the cynics get you down. more than one person has been duped by claimed better injectors in the past. doing anything to these motors is going to cost money. if you can build a better product, do it and they will come.
best proof is if you can compare the spray pattern, pop pressure, and most importantly fuel volume between the stock vs. modded unit, that will be the seller.
if nothing else, for your own satisfaction is good enough.
thanks for being willing to push the envelope.
Im in no way trying to shoot down your product, if i can see its worth it then i woudl buy it, but i couldnt see paying 500 dollars for injectors if there not worth 500 dollars, and does it take 500 dollars worth of that material to bore the holes out on old used injectors? cause its just about 300 for new injectors and a return kit. im just trying to figue out how we get 500 dollars from that, now if it does take 500 dollars and the injectors really make a difference then i would be willing to pay it sooner or later
