One decent truck out of two.
89Laredo
Underemployed
Sheffield, ia
Apparently I can't count to six... :facepalm: :mad:
89Laredo
Underemployed
Sheffield, ia
Missed the bolt above the slave cyl Mount...
89Laredo
Underemployed
Sheffield, ia
Has an international flywheel
This is why I pulled it
Been leaky for a while apparently.
89Laredo
Underemployed
Sheffield, ia
TOB and ring gear ordered, in Monday.
Forgot the clutch alignment tool.
opusd2
BFE, WI
With the 4 speeds, I usually leave the bellhousing attached to the engine and leave the tranny hanging as you did. I've done it a few times with my 73 F100 replacing the 360's clutch a couple of times as well as my Dad's 79's clutch a couple of times. Hauling heavy loads on the farm does a number on clutches. So does a driver who drags the clutch unnecessarily. The important thing is, you got it out! :)
I think I am replacing the C6/1345 combo with a T18/205 combo I am getting in trade for an old truck I have. Your thread makes for good learning. Gotta love Midwest Rust! I just have to figure out if I am going with what I am used to, and that is an unassisted clutch or fitting in a hydraulic one. I think the bellhousing I have has provisions for a slave...
And I like your taste in tractors and other equipment! Is that a 1066 in the background? Good luck! I'm subscribing
89Laredo
Underemployed
Sheffield, ia
I think it's a 1066. There's many tractors around. Some are Jed's, some are back burner projects for customers.
The main tractors are the 560 for work around the house and the 1980 186 hydro. He uses the hydro for pretty much everything, it's his baby.
There's a 5088 in the shop that's been torn apart for at least 5 years, he wants to get it back together but doesn't have the time.
And a 3088 that gets used maybe once a year to run the driers.
My c6 truck has a 208. Not sure what the t19 truck has, it's a bw tcase.
Gonna work on the trucks till 4 today, then get cleaned up and go to the ntpa tractor pulls.
http://www.rockwellialions.com/tractorpull.html
Going to swap interior pieces, move radio/amp/sub/etc.
89Laredo
Underemployed
Sheffield, ia
Didn't get much done. Pulled seat out of black truck and trying to figure out the cf of wires in red one.
Put 3.5qts of 40w oil in red truck trans.
89Laredo
Underemployed
Sheffield, ia
Didn't get any work done on the truck today. Was hoping to have the motor ready to pull.
Had to help with this CF instead.
Broken rear yoke on truck, stuck. Tried Jeep, wouldn't budge. Tried 560, got it stuck. Finally tried pulling it forward with the other tractor and got it out.
89Laredo
Underemployed
Sheffield, ia
Got black truck pulled under the A frame and 5 gal of coolant drained. Went to tractor pulls again. Hoping to have motor out tomorrow, we will see if the weather lets me.
85s last run before ripping it's heart out.
85s Last Run: http://youtu.be/rvT7xo-WKZs
