CURRENT SAMPLE
Customer Corey Zakeosian Jobsite Default
Serial No Corey Z 7.3 IDI Unit No F350
Model 7.3L Make Ford
Oil Type Royal Purple Synthetic Oil Grade 15W40
Compartment Diesel Engine Compart Serial
Job No 10000/5000FILTER Meter 125483
Lab No 121203924 Sample Date 17-Dec-2012
Eval B Sample Site
DETAILS
17-Dec-2012 18-Dec-2012 125483 miles
13-Jul-2011 18-Jul-2011 107105 miles
ELEMENT TESTS
Lab No Eval Cu Fe Cr Al Si Pb Na K Mo Sn Ni Ag Ti V Sb B Zn P Ca Mg Ba Mn Cd
121203924 B 6 260 3 4 12 41 36 57 28 1 6 1 1 1 1 26 1178 979 2412 14 1 2 1
110704130 B 11 80 1 2 7 18 15 7 27 1 2 1 75 1 1 71 1161 1036 2062 238 2 1 1
LUBRICANT TESTS
Lab No Eval Visc Label Visc SAE Kine Visc Soot Sulf Oxid Nitr Antiwear PQ AF Fuel Calc Water
121203924 B 15W40 50 18.6 89 21 14 9 17.25 20 N 1.0 N
110704130 B 15W40 40 14.1 33 20 16 8 19.59 12 N 1.3 N
COMMENTS
Lab No Eval Comment
121203924 B The analysis of the oil sample taken from your Diesel Engine indicates that readings are higher then normal. Engine application/operation changes; excessive idling and maintenance practices can effect these readings. Soot level is influenced by fuel system operation; lugging and or inlet air restriction. Copper; Sodium and Potassium are early indicators of antifreeze contamination developing. Check to see if coolant level is going down, if not adding extra coolant and or water watch coolant level and next sample for any change. Continue observation of this compartment with proven preventive maintenance practices and sampling at manufacturer's recommended intervals.
110704130 B The analysis of the oil sample taken from your Diesel Engine indicates that readings appear normal at this time. Engine application/operation changes and maintenance practices can effect these readings. Watch next sample and oil level for any change. Continue observation of this compartment with proven preventive maintenance practices and sampling at manufacturer's recommended intervals.
theres the results. the lower row of numbers was my first sample taken back in july 2011. used kendall titanium motor oil then. now i am on RP full syn. the soot number i am sure has to do with the moose pump. the traces of coolant has me a little worried.
Eval B Sample Site
DETAILS
ELEMENT TESTS
LUBRICANT TESTS
COMMENTS
Lab No Eval Comment
