Thanks for your response and yes it is an ATS 093. If you look on the front of the circled portion, there is a gold bolt I threaded into it to port off that section. I just wasn’t sure if there is a flow to it? I seen a guy who rebuilds these and it was turned around according to the numbers on top.That looks like the correct orientation. I don't think that you can get it wrong. If you do, you won't be able to attach your oil feed line. That looks like a ATS 093 or a Factory Turbo which are basically the same thing. I don't believe that there is an extra, blocked off port. There's two mounting holes with bolts in them.
Hmmmm maybe it is a different turbo then. Everything else about the kit is ATS 093 with the air box and bigger down pipe.That doesnt look like the ats 093 turbo I have, unless you have an OEM style turbo. Mine just has a simple JIC threaded port on the top for oil inlet. My oil pressure sensor is still on the back of the block, I just added a tee for it.
Also hello from Portland
