oil cooler
rodney350
bullard texas
ford dealer mechanic believes if i'm getting water in the oil and oil in the water that i should replace the oil cooler tube. does everyone agree with that?
Exekiel69
Not necessarily, You could have a blown head gasket but then the cooling system would have a lot of pressure or You might even blow white sweet smoke out the tail pipe or better yet a cavitated engine. Of all that oil cooler would be My favorite and easiest to do.
Ya cain't diagnose an engine if ya don't know what it is. Put your truck in your signature.
What you describe sounds like the oil cooler o-rings have hardened and are leaking but.. You could have other issues too. I feel your going to have the dealership do any work thats needed so.. Have them remove the oil cooler and at least check the o-rings.
