jdchristian3
my wife's oil cooler recently started leaking oil to the outside. she noticed it and drove straight home. it was a purty good leak... called ford. said bring it in, its not an oil cooler. i said OK. turned out i was right. they then said with the leak it has there is no possible way the water got in the oil. took an oil sample, but still waiting on the results. i say, according to the blow apart diagram i got, the it most likely leak water into the oil. any insight is helpful. THANKS A BUNCH!
