4x4manonbroke
Diesel Master
Ok so I recently changed both my fuel filters filled them both with clean ATF as usual.... I'm runnin a boi-tech 10 micron filter and a Baldwin BF-1222 fuel/water seperator........ there was no studdering at first and and it pull great as usual... but occasionally I get these blue puffs when I shift from high rpm's..... never happened before.... fuel system has been go through fron to rear.... no air in fuel I already replaced all fuel lines and fittings ... no runs great after all that.... thinking I might have a pump thats leaking now ???? and occasionally when I start it up after running it .. sits for around 15 min. it will studder and smoke and stumble and then clean out and idle just fine... some times it smokes for a min... and some times not.... I'm kinda corn flustered as what to do ...
