Not-Charging Frustration
The_Josh_Bear
Western WA
Forgot to mention, Stick Witch, that, while running and not charging, the alternator warning light did NOT come on.
I've heard of alts not charging if that bulb in the dash burns out, too. Something to keep in mind I reckon.
Easy way to test is: Key On Ignition Off, you should have a small Christmas tree of lights, one will say BATT maybe a picture of a battery, I can't remember. If not, bulb is out or circuit is disturbed. Guess we forgot that little tidbit in the early stages of diagnosis...
Cubey
Van dweller
USA
Passenger side has very little room, due to the heat flap-box. That side gets an uncommon group 50, which is very narrow. Only 600 CCA. Fortunately, my part of the world only gets around freezing may be two weeks out of the year, and the block heater works great.
Eww. Shame on Ford for doing that. 91 vans and older can fit a 65 there.
O'Reilly is selling an economy 50: https://www.oreillyauto.com/detail/...-economy-battery-group-size-50/50ecoj/4742709
laserjock
Almost there...
The Warning bulb being bad in the OBS trucks can cause a no charge issue right? I have no clue on a van. I lost track. Did you hot wire the alternator and see it charge?
idi_econoline
No Bed For Me!
Northern California
Work's been rough this week, so, finally got it all back together, just now.
NO CHARGE!
Back to Stick Witch's advice: replace the wiring!
Well, at least the small wiring -- the fat red output wire should be fine. Have already proven that no charge is coming out at the output terminal to the red wire.
Just. Wow. :(
idi_econoline
No Bed For Me!
Northern California
Didn't pay attention to the light before start The light wasn't on before; the light (pic of battery and the word "AMP") now comes on and GOES OUT once the engine is started, as if the alternator is charging. Think I'll recheck output at alternator terminal one more time before disassembling, again.
Dunno. :mad:
Maybe use two or three different methods of testing. One may not be working right. Seladoor had this problem with his alternator. It was his DVOM.
idi_econoline
No Bed For Me!
Northern California
Please convince me that I need to replace the wiring, Stick Witch.
Green wire good continuity, from alternator connector to plug next to battery.
White wire continuity good from connector to connector.
Yellow wire continuity good to solenoid.
Alternator connector new last weekend.
Alternator tested good at O'Reilly's, 15v, on 3 tests. AND a reman replacement; same symptoms as old alternator (should've tested it)
Both batteries replaced; both load test fine.
Again, using DVOM and load tester's gauge to check voltage.
What am I missing, that I'm getting no charge, and it happened suddenly, after sitting for two weeks?
AND the dash volt gauge reads low, though voltage to cluster same as batteries, at fuse panel.
Feeling very lost.
stick_witch
Homer, Alaska
Feeling very lost.
Sorry, I’ve had a busy week. Did you ever check the battery light on the dash? Not the voltage gauge but the actual battery light? If the truck is running and the green wire is connected properly and theres no charge to the batteries then that battery light should be coming on in the dash. Its my understanding that the light excites the alternator and without that light circuit it won’t do that. Easy way to check if the light works is that when you turn the ignition all the warning lights in the dash should come on and you should see a red battery light, if you don’t then thats a problem. Also check your continuity from the green wire up to the dash light.
I doubt your troubles are at the 3 prong pigtail if you replaced it and connected it all properly which it looks like you did. Again, don’t go by color, go by the “a s i” stamped on the alt case. Im guessing your issues are either that green wire to dash light, or at the solenoid to battery connection. Please send a picture of your new solenoid with everything connected.
idi_econoline
No Bed For Me!
Northern California
Tried to make this somewhat vertical. Maybe only 3 inches between solenoid and the group 65! I could remove battery for a better shot, if that helps.
stick_witch
Homer, Alaska
Okay, I don’t see your 6 gauge battery hot connection from the battery to the hot post of the solenoid. I think I see it coming out of the loom next to your 4 gauge alt output (it’s the slightly smaller red wire). I can’t see where it’s connected on either ends, but nonetheless I don’t see a battery connection on the post with your alternator, which equals no charge to the batteries.
stick_witch
Homer, Alaska
Here’s a picture of my truck. There should be that yellow wire, the black and orange wire, your alt output wire, and the red, 6 gauge connection to your battery positive in the black loom.
I see the yellow wire, the black and orange wire, and the alt output wire on yours, but no battery connection. This would explain a lot, because its totally possible that you have a hot wire supplying enough power to the solenoid that it will power the trigger wire and IP to start the truck, but once its started, theres nowhere for the alt output to go in order to charge the batteries, which explains why you have no charge to the batteries at all.
