Normal engine oil temp
cbarm
Medicine Hat, AB
Hey guys...I know this is the wrong section for this but the PSD in my '90 sig. truck is runnnin a lil warm I think. Is 220 on the hot side with normal drivin? 60 mph @ 1950 rpm not towing and about 40F outside now...
WhiskeyBottle2
TX
Boiling oil, boiling oil...what temp does oil boil?...BTW...220 degrees seems normal to me...just saying...
89greendiesel
columbus
i'd be "cool" with 220 unless it is different from what the temperature usually is
220 isnt not hot for oil imo
cbarm
Medicine Hat, AB
ok...I just wasnt sure cause I just put the sender in today. The oil on my '89 IDI turbo usually runs at 190 or so...
No problems running that temp oil. Oil must get hot enough to burn off the products of compustion that slip by the rings.
