vt951
I've never seen 600rpm with a starter, but 300rpm via the dash tach is common.
Yeah, I just watched the video from the TN thread with the start up rpm, and it looked like only about 300 rpm on the tach.
That glow plug mod is common, especially on the 6.9L because of the type of glow plug controller they use,I have heard it likes to fail in the on position.
I just went ahead and got another Ever Start Maxx with 850 cca's so hopefully the old and new batteries will be matched well enough.
So, with a button like that, what is the start up procedure? Turn the key to accessory position, push glow plug button for x seconds, and then crank it? Or push the glow plug button until the glow plug light goes out, then crank it?
Rule of thumb is to replace batteries in pairs unless the one is not old. These trucks should have matching batteries or one will drain the other and starting won't be so great.
And you learned all that from just reading old posts, huh? I didn't think that was possible, maybe some people just don't think to try that route.![]()
I read something about that, but the good one tested very good after charging it up. It held 13.3 volts, and made 887 cca's.
It cranks much faster now, but still doesn't turn over, and I'm not seing any smoke coming out of the exhaust, so I'm going to head down the fuel system troubleshooting path now.
Thanks everyone for your continued help.![]()
A guy at work is telling me that ether is the way to go for my situation. Just a little shot while it's cranking, and maybe that will be enough to get it to turn over, push the air out of the fuel lines, etc. I read somewhere that it is not a good idea to use the glow plugs when using ether. True? If so, it looks like I can start up my truck without the glow plugs even being pulsed, because I have a manual glow plug button.
