vt951
Hello all. New to diesels, sorry for a couple dumb questions here, but I'm hoping to get some advice.
I am buying an '86 f250 with the 6.9 and 4x4. It doesn't run, so we're going to try to tow it to my house using a dolly, about 20 miles. Should i pull the driveshaft for that distance, or do you think the tranny will be ok for that short distance?
The reason it doesn't run is the owner pulled the injectors to clean them, and I guess didn't put them back correctly. He said he thinks he put them in the wrong order... but that doesn't seem to make sense... they should all be the same injectors right? From what I've read in Mel Agne's (excellent) instructions, I suspect there is probably just air in the fuel lines.
Getting the truck for only $500 because he's moving and can't take it with him! Body is pretty good (no rust through), Texas truck supposedly, but paint is toast. I plan to remedy that.
