This is my first post after lots and lots of reading. I've been on the lookout for a tow rig for some time and recently purchased a 1986 F350 6.9 married to a 4 speed. I bought this truck with the main purpose to tow my trailer and Bronco - I've been borrowing a 99' 5.7 Tahoe with success, but it's time to tow my own weight.
Here is a shot of the truck and what it will be towing -
This is my first diesel and I'm going to admit there is a lot I don't know about them when it comes to proper starting and driving techniques, maintenance and fuel requirements when it comes to additives.
The truck starts right up and runs good (to my limited knowledge) - it will blow a little smoke if I get on it hard, which seems to be normal. I don't think the pump has ever been touched as this was an old man's farm truck it's entire life. The only modifications I can see is a K&N air cleaner (carb style) was installed shortly before I got the truck - made a bit of a difference over the factory setup. Other then that, the exhaust seems to look factory, but the truck is loud (I don't mind it - sounds cool )
Startup - turn they key on, glow plug light comes on and when it goes off I can start, I know that much. Should I let the truck idle a but before taking off or is it ok to drive it nice right away? I'm going to guess it depends on the temperature outside, if it's damn cold out, let it warm up a little?
It seems very typical of people to leave the diesels running quite a bit, is it ******* these trucks to shut down for a short period of time and start back up? Should I let it idle when I run into the liquor store for a six pack?
Additives - I read about in the late 90's the sulphur level changing and it affecting our 6.9 trucks, should I be using an additive year round? Any specific brand to look for? Any negative affects from adding too much?
Thanks for your input - I want this truck to last a long time and serve me well. I plan on replacing the glow plugs before winter, new tires and all new fluids from the front differential to the rear.
Kyle
Kyle
