83ford
ford diesel baby
No but I will tommrow what should I notice with it unplugged and should I run it on stock or a one of the tunes
Sent from my Iphone using Tapatalk
For the CPS, get an Echlin from NAPA, proven to be about the best.
I would also check that the nut on the back of the IPR hasn't come loose, and check the ICP sensor for oil leakage as both problems would effect idle quality and throttle response.
The last vid, was that pedal all the way down?
Then I would get ahold of something to check icp and duty %.
Also make sure to check the uvch. Mine sometimes does that after changing the oil when it's pretty cold out.
I would recommend trying some hot shots secret stiction eliminator/injector cleaning. It goes in the oil.
