the parts will interchange. if you are allowed to get anything and everything, index all the lifters before you pull the cam. the rollers should be interchangeable, but I'd keep them organized just to keep the wear patterns the same.
Cool, gonna try to get all the parts off that truck this weekend if it works out, hoping he keeps his word. We shall see. Can I get that lifter retainer from the dealer if the deal falls through? Always nice to have a backup plan.
Yup, like Calvin said, the cams/lifters will interchange. I was thinking about that lifter failure and wonder if the broken retainer cause the lifter failure or the other way around. If the retain broke, it would let the lifter rotate in the bore and it's oil galley would no longer line up with the supply oil galley in the block.......... letting it get dry and fail/sieze in the bore. Or if something cause oiling failure to that lifter letting it seize in the bore and breaking the retainer????
Who knows........ just curious what happened.
Heath
I have been thinking about how it failed as well. I got the cam out today and sure enough the lobe is pretty flat, so I will be needing a new cam. I got my magnet to help me work the lifter out and before I could get my extended needle nose pliers under it the thing fell and landed in the oil pan. Gonna drop the oil pan to get it out and I will post some pics up and maybe it will give some clues as to how it failed.
On a positive note, the lifter bore is perfect and not damaged at all, nice and shiny and smooth just like the others, so I am very happy about that.
Another question, are the IP pumps from a 7.3 any different from the 6.9? Would it be worth it to nab the IP too? If he lets me I am going to take it just so I have an extra one. If all goes well, by the end of the day Sunday, this thing should be running.
I will be having some questions about getting my timing back for my pump, some things got moved around when I was taking the cam out so I am just going to line the crank and cam up and figure out where the pump needs to be in relation to that. Getting excited about getting this thing back together.
