New speedo gear suuuuuuuucks
The_Josh_Bear
Western WA
So I recently switched from 4.10 to 3.55 in the rear and finally got around to the speedo gear swap yesterday.
But it doesn't read really at all. Under 25mph it doesnt read and at 80mph it reads 40-45 at best but vacillates pretty wildly the while time.
I took it out to reinstall it and nothing changed, tried it a 3rd time and nothing better.
I can say the gear itself is already worn and has a little dish to it after just two days driving to work, 17 miles each way. But the dish is like a nickel only 1/16" deep, far less than the gears should be meshing, right?
My old OEM gear was perfect all day every day. It was 19 tooth. I did math and figured my gear to be right between 16 tooth and 17, so I did the 16.
The new gear was off of Ebay but has the same stamp as the gear that came on my rig. "LEM" or something.
What am I missing guys?
Thanks,
Joshua
The_Josh_Bear
Western WA
I wonder, maybe the wrong gear? Is the diameter the same as the old one?
I guess it must be? Looked pretty close the other day but of course I was getting over the flu and wasn't all there. I'll put my calipers on the new and old to compare.
YJMike92
NW Arkansas
I never paid attention to the mounting on my Fords but some rigs have a speedo gear housing that allows the driven gear to be turned closer or further away from the drive gear. Do our Fords have that kind of set up?
The_Josh_Bear
Western WA
Well I mic'd the old gear and new gear of the same tooth count(19):
And here's a 17-tooth:
I'm no machinist but I doubt these variances would cause my issue. I'm sure the 16 tooth is just that much smaller but still... maybe the gear inside the tcase is worn also? Is it plastic? How stupid would it be if it were plastic :frustrate
FordGuy100
Silverton, OR
The gear in my transfer case is stripped as best as I can tell. Perhaps thats your problem too.
BrianX128
Pittsburgh
They seat strange sometimes. Mine worked great and then I unhooked it to get some slack to pull it from the dash to change bulbs in the dash and it shook. I pulled out the trans side and re seated it and now its fine. :dunno
laserjock
Almost there...
This^
I changed my gear and the new one worked half way for a short time. The drive gear inside the tcase housing was worn.
You can see it down through the hole even. Took picture in truck with phone.
Not that hard to change. I changed the rear seal at the same time.
If you do change the rear seal make sure it’s driven solid. Mine popped out and emptied the tcase going down the interstate coating the front of the camper.
[emoji849]
The_Josh_Bear
Western WA
This^
[emoji849]
Thanks for the photos! Looks like a lot more work than the speedo gear was... grrr. Good call on the tail shaft seal as mine leaks a little anyway.
Did you have to drop the tcase or is it doable in the pickup?
Cv axle
