88 Ford
cylinder head flow has a effect on torq and hp but not quite the way you might think. when I increased head flow on the intake side the torq numbers moved up the rpm range. if I raised the boost it would move back down again. but would peak at a higher rpm. If I raised exhaust flow the turbo would spool faster and torq came on sooner. The flow rate on the intake is less important than the pressure. lobe lift has a similar result. adding lift to the cam made bigger numbers in the higher rpm range. adding duration to the cam made everything move up the rpm range to but dropped boost at the low end. I think there are gains to be made from mild port work on the intake side, but dont make the port bigger just remove obstructions and port matching. The exhaust side needs the same work with special attention to keeping the size of the port and the manifold from changing size so the gasses dont expand until the turbo. "This info came from a article in diesel truck mag" . I put that info into the dyno and it made 8% increase in torq and 6%hp. on the stock engine, and 11% and 9% on the type4. Now when you look at piston design you find the IDI has a dimple and two round depressions for dispersing the flame from the pre chamber. The di engines can use a recessed dome piston so the fuel/flame can move out from the center. I want to do some research on piston design to find the best way to lower static compression and get good fuel/flame movement into the cylinder head at the same time.
So according to the program, you got those hp and torque gains just from port matching?
And as for the dimples in the pistons, aren't those dimples valve reliefs?
