There are now three cams available. The Typ4 cam is a lower rpm cam that was build originally for NA engine but seems to make really good power on even turbocharged trucks. I am curious what it would do in a high horsepower application.
There is also the J2 cam, which is more of a higher rpm cam. There is some dynamic compression bleed off with that cam. It makes nice power in high power applications and pushes the horsepower and torque curves up a few hundred rpm.
There is also the R&D Performance Stage 1 cam. It is more of a low to mid-range cam. It, like the J2 cam, was built for use with a turbo. It also will bleed a little compression but not quite as much as the J2.
Overall, all three cams are really good cams and have better power curves than stock. It just depends what you want from your engine and where you want the power to be.
