Waystro
No Class
Cool SA here but working in East Tx around silsbee. Like I said I got a sterling with 3.55s Srw with 160k of you want to trade them let me know.
You're talking about regearing both trucks? They actually have different gearsets from the factory, however they are interchangeable. The '94 gears are better design in that they have stronger coupling to the yoke for the driveshaft. If you're about to order two identical sets of gears do make them both for a '94 truck, then your '91 will get a nice upgrade. However do keep in mind the newer design gears will need a newer-style yoke as well. Front axles are Dana 60 in both trucks, and those do take identical gears (assuming both trucks are 4.10-geared now), you can order two sets of the same kind for them no problem.I am looking at gears for the axles. Axle is a Ford/Sterling C5 with 4:10's, I assume it is the same axle set for both so I can order two sets of gears.
Go 3.55 and don't think twice. The 3.73 will only raise your cruise speed by about 5mph, IMHO hardly worth the expense of purchasing new gears and having them installed. The 3.55s will give your roughly 10 mph faster road speed, bit more noticeable in the MPG department.The big decision will be 3:73 or 3:55. My gut says go with the 3:55's as this truck will be mostly a highway truck. It rarely ever does towing duty but I will tow an 18' bumper flat bed trailer, nothing very heavy, and the heaviest thing will be a 3500# tractor. I am looking mostly for fuel economy, with the 4:10's first gear is useless to me, it starts out easily in second, I have to keep it floored to even see 70 mph, and that has to be fixed.
Yup, I do. Actually what I regret was installing a factory diesel-spec ZF in a truck with 3.55s, for our yard goat needs 1st in high range was too high and reverse was even worse, and being stuck in low range all the time does get annoying after a while. Remedied that with a wide-ratio ZF so we can putt around in high range most of the time, much better for my sanity. Naturally there is no free lunch, the price for having both low gears and nice overdrive is the engine speed gaps between the gears that can hit 1000 RPMs - most folks would hate driving something like that, if you ever drove a 70s Ford with a creeper 4-speed imagine that with your engine under the hood. Point is, you may wanna consider leaving your water truck with 4.10 gears and just replace the E4OD with a standard diesel ZF (if it needs it) and call it good. For the truck that goes on the interstate and doesn't spend much time crawling around your property ZF with 3.55s will be pretty great.Does anyone regret going to 3:55's with the ZF-5?
You mean these here critters:That makes sense, as time permits I will do some more shopping and report back. I did learn about the yoke differences and I am actually considering the OEM set found here...
http://eastcoastgearsupply.com/c-61...spider-gears-ford-ford-10-25-inch-10-1-4.html
You'll be fine. We recently dropped in a new t-case that shortened the rear shaft by whole inch and got it right where I think it's darn near perfect - meaning up until now it was a full inch longer than ideal, and it didn't care on bit, no vibrations or anything.Won't that mean a different driveshaft as well? Won't a shorter yoke mean the driveshaft will then be too short?
