New member, old trucks.
SirRea63l
Tx
Reviving this, just to keep everything easier to find.
Got the replacement shock for the rear and got them installed. I still have to get the fronts in. I have a new minor issue, sending unit on turbo, leaking like crazy. Is there anything special about these or will one from Napa do the trick?
It has been leaking a while, but it got really noticeable today.
I hope to put a real oil pressure gauge on it soon, and I am assuming the replacement for this will need to be a different sending unit?
I also ordered a set of GlowShift gauges, pyro, boost and water temp and an a-pillar pod for them. They should arrive next week. I am not really excited about GlowShift but they will work for now.
That one's a pressure switch, you can replace it with a real pressure sender and modify the gauge cluster so it'll work as a real pressure gauge, just won't be calibrated with numbers.
SirRea63l
Tx
I ran to O'Reileys and picked up a cheap replacement for now, it was ten bucks.
