New Guy needing help! CDR grommet
94f450
Greenwood, IN
I have a 94 factory turbo truck, when I was pulling the valve covers I had to pull what I believe is called the CDR on the drivers side cover?:dunno The grommet that plugs into the valve cover is in half and hard as a rock. It seems to be discontinued from ford! Has anyone found a replacement!?
Contact typ4 (Russ) here. I think he may have several of these difficult to find grommets.
typ4
Newberg,OR
Nope, all out and none available,..Ats does ahve a Kit with supposedly all the seals in it for 40 ish, call them, ask for Pat
hesutton
The Anti-Anderson
Bowling Green, KY
Is is the stock CDR grommet or something special that ATS uses?
Any photos?
Heath
TWeatherford
Flagstaff, AZ
If you know the dimensions, I would look at mcmaster.com. Or if you have a good rubber and gasket shop around they will likely be able to find one for you, by dimensions or if you just bring them the two parts you need to make a seal between they'll go off that. There has just got to be one that would fit perfect that is commonly available, but finding it may be difficult.
Maverick1701
Memphis, TX
I think you can order one from the IH house (cant remember if that was just the CDR or grommet too)
