MotleyCrueCab
Registered Abuser
Gotta call from by boss about 2 days ago, he was driving clients around when his 01 7.3 started leaking oil and loosing power. He pulled over, shut it off and call AAA, and I can to pick up our clients. there were oil drips to the truck about about 2-4 quarts under the truck... I feared it being a rear main seal.. Pop open the hood and there is oil all over the valley... I figured it was something blew out in the HPOP system or reservoir. Got the truck home, put 2 gals in it and filled the HPOP reservoir. Cranked a lot, but started. I looked and see no obvious leaks...shut it off .... start again, cranks for 15 sec before it fires... let it warm up for 10 min while watching it. look under the truck and can see a steady stream of oil coming out where the tranny meets the engine. Any ideas... I'd like to have a clue of what i'm getting into before i tear everything off so I can find the leak.... Is there an oil plug or something towards the back of the valley that is prone to leak? Also.. if something is leaking in the valley, where would it drain out on there engines?
Thanks,
Mike
Thanks,
Mike
