Mystery hose
screwhead
Austin, TX
1993 7.3 idi N/A
Howdy hope everyone is running well.
I have a seemingly broken off 5/16th or 3/8th hose, one end is on a little panel with some other hoses connected to it the other end I have no idea where it’s supposed to go and can’t find any valve or anything that it should go to or can reach I was hoping someone could identify this hose and what it goes to for me, also what is the little panel it’s connected to called?
Thanks!
Almost looks like the hose that goes to the vacuum sensor, if it is, just cap it off.
mf7lakes
North Carolina
It's called the vacuum distribution block & they are correct -- that hose is supposed to go to the low vacuum warning switch on driver's side of radiator near battery #2
mf7lakes
North Carolina
Whoops -- I'm wrong -- that hose is supposed to go to the vacuum check valve connected to heater/vent/defrost stuff
