Goofyexponent
Mentally Unstable..
Well,I went out at 830 am and it's not 130 am.....rad and coolant changed, oil changed and she's greased.
The rad went in pretty well, not an EXACT fit, but close enough for me!!! I had to remove two of them factory mounting tabs (the one that the screws thread into) and wind in a couple 1/4" stainless bolts, washers and double nutted them on the top. My truck was involved in a front end collision before I got it, and I assume that's what caused the misalignment.
Other than that, its a 100% drop in piece. Looks REAL good and this one don't leak.
Now, about my factory radiator.....I don't know WHY iot wasn't replaced when the truck was in it's crash, but rather than replace it, the PO had about 50 tubes pinched off top and bottom, then covered over with solder. The upper tank was dented pretty badly, but just soldered up to not leak.....didn't work.....
I don't know how this thing was staying so cool with that rad the way it was
NOW, the only thing I got to ask....I pulled one block drain, but the other was seized in. I flushed the best I could but TOTALLY forgot the heater core...it was filled with green coolant. I dumped in about 3 gallons of CAT coolant (pink concentrate) and then 2.5 gallons of distilled water......but there was enough green crap left in there to turn it all green again.
Is this going to cause me issues? I plan on putting a coolant filter later on, but not for a little while. I could change it all out then, but what will it hurt?
